Other i7 930 @ 4Ghz vs QX9650 @ 4Ghz Vantage benchmark
Discussion in 'Hardware' started by Guest-44432, 4 Jun 2010.
  1. Guest-44432
    Guest-44432 Guest
    i7 930 @ 4ghz HT enabled. PC specs in sig. HD5970 stock (735/4000)
    QX9650 @ 4Ghz, Gigabyte X48-DS4, 8gb DDR2 1066 5 5 5 15. HD 5970 stock (735/4000)
    Looks like the Core 2 Quad is a bottleneck for the HD5970.
    Simon.
  2. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    To be brutally honest, the conclusion is not valid. 3dmark results are based on different tests, some stressing the CPU and some stressing the GPU. The calculations are averaged in some way, and the result makes up your score.
    At best, 3dmark is good for comparing gpus to other gpus, but with CPUs the score is almost meaningless. In most games, (GTAIV being the massive exception, and Source to a lesser extent) the difference between one fast CPU and another fast CPU will be minimal, you're talking between three and five fps, tops.
    So yes, you could say that the C2Q is a bottleneck, but it's only a bottleneck for the 5970 in 3dmark. Apart from that, your scores will differ massively. Try it in a few games. You'll probably be surprised how close the two results are.
  3. Davzyii
    Davzyii What's a Dremel?
    8 May 2010
    I am upgrading from an unoverlocked q6600 to a core i7 930 and I have a 5970 as well so its good to see that this will help me in getting more performance as I thought it would.
  4. robots
    robots What's a Dremel?
    27 May 2010
    Does the i7 930 overclock much better than the 920? Is it worth the extra £60 or whatever?
  5. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    Wow! the CPU score difference is amazing.
  6. ripmax
    ripmax Minimodder
    8 Apr 2010
    The difference wont be that big in most games, i don't really see the point in upgrading to an i7 just for benchies.
  7. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    And its not just the CPU, it'll be the RAM too...
  8. Guest-44432
    Guest-44432 Guest
    Wrong. :D
    I have found that running games with 8xAA with the i7 has given me better minimum FPS by a good 10-15%. (Better minimum = Smoother game play Especially in Crysis)
  9. Guest-44432
    Guest-44432 Guest
    I have never owned a i7 920. But my 930 is Prime stable @ 4ghz. I reckon I could push up to 4.3-4.4ghz.
    I only paid just over £200 for my i7 930, so the £30 difference is up to you.
    Simon.
  10. Guest-44432
    Guest-44432 Guest
    More due to the fact that HT was enabled.:thumb:
  11. Bakes
    4 Jun 2010
    It depends on what your processor is like.
    Intel has become much better at binning different processors in the last year or so, and so you're less likely to get a brilliant 920. Having said that, Intel's also got better at making Bloomfield cores also, so there are less rubbish processors as well.
    Personally, I've got my i7 920 up to 4.2GHz with relative ease. Maybe I'd get it a little further if I had a 930, but I'm not sure of that, the limit is likely to be around the same amount.
  12. robots
    27 May 2010
    Thanks :) I think I would be happy with either chip anyway.
  13. Bakes
    4 Jun 2010
    I never said that the C2Q isn't a bottleneck. I just said that the result you showed, that the score is higher in 3dmark with an i7 doesn't prove that the C2Q is a bottleneck. It's real games you'd want to be testing to try and show that.
